Export Failure IGES - Hollows out to a shell
Hey Everyone,
Whenever I export my files to IGES or Step, in Team Center they appear as shells instead of Solid Bodies.
Does anybody know how I can fix that?
here are screen shots of my settings while exporting to IGES
Re: Export Failure IGES - Hollows out to a shell
HI Elif
Export IGES is shell. Export STP is of Solid Bodies
Nice to answer your question
Thank you for your reply but I get this error when I convert a solid body to STEP too.
Drawings are not solid body, drawing my side to help you see OK,
Must be a paper data problem.
Hi @Elif,
How are you determining that the bodies are shells in Teamcenter?  Are you opening the resultant IGES and STEP files in another product integrated with Teamcenter?  Have you tried importing the STEP file back into NX?
As @FZK stated, the IGES translator converts solid bodies to sheets.  The STEP translator should maintain the solid bodies. When you export using the STEP translator a log file is created in the destination directory. Open the log file in a text editor and review the output.
The top of the log file should report something similar to:
! SUMMARY-  Entities Processed             Count
! SUMMARY-  ------------------             -----
! SUMMARY-  Line ........................:     9
! SUMMARY-  Arc/Circle ..................:     2
! SUMMARY-  Part Attribute ..............:     1
! SUMMARY-  Font ........................:     1
! SUMMARY-  Color Table .................:     2
! SUMMARY-  Coordinate System ...........:     1
! SUMMARY-  Parameter ...................:     1
! SUMMARY-  Matrix ......................:     2
! SUMMARY-  Solid .......................:
! SUMMARY-      Body .....................:     1
! SUMMARY-                                 -----
! SUMMARY-  Total                             20
The bottom of the log file should report something similar to:
! INFO-     Total number of solids input for this translation  :       1
! INFO-
! INFO-     Number of solids processed without problems        :       1
! INFO-
! INFO-     Number of solids with problems output as sheets    :       0
! INFO-
! INFO-     Number of solids not processed                     :       0
How does your log file compare?
Regards, Ben
