Export IGES ERROR
Hi every one
I am using NX9.0.3 MP16 . I found a problem when I export file IGES . Please see in attch file .
Thank you
Re: Export IGES ERROR
Hi @22,
What is your Windows OS "locale" set to?  You can find this under "Region and Language".
It seems that whatever it is set to is not a supported locale.  Try changing it to a different language, such as English, to see if your translation completes.
Regards, Ben
