Export PDF on save
Solution Partner Builder Solution Partner Builder
When I save drawing on Teamcenter it does not create pdf automatically.
I found some properties on Customer Default -> Gateway -> Pdf Export, but that doesn't work.
1 REPLY 1
Re: Export PDF on save
NX does not have an option to create PDF's automatically.  Natively, or when managed by Teamcenter, you could execute an NX/Open program when Saving to a export PDF of each sheet in the work part.  Alternatively, when managed by Teamcenter, a command line utility (export_ugdwgimages) can be executed (typically overnight) to create PDF's via dispatcher.
Regards, Ben
