Export parasolid with Attributes
Hi..
I need to export parasolid file from UG NX with the user ddefined attributes. How do I do that ?
These attributes are of integer and string type.
Sathish
Re: Export parasolid with Attributes
Hi @SathishKumar
Are you referring to Part Attributes or Object Attributes?
Those are not supported with Parasolid export.
Name and color attributes assigned to objects are exported.
The JT and STEP translators provide better support for attributes.
Regards, Ben
Thanks for the information..
