Export pdf on linux
 I tried to export a drawing to PDF on a Linux machine
The operation failed and the syslog file includes the message:
Failed to start $UGII_BASE_DIR/nxplot/bin/pdf/cgm2pdf: No such file or directory
Is this functionality unavaileable on linux?
Moti Eitan
3 REPLIES 3
Re: Export pdf on linux
As far as I can find out it is supported on Linux (at least the release notes don't mention it isn't supported).
What version of NX?
Does the $UGII_BASE_DIR/nxplot/bin/pdf/ exist on your system?
Did you install all the options when you installed NX?
Anthony Galante
Senior Support Engineer
PhoenxPLM
What version of NX?
It is an old NX6 version, but we will install NX8.5 soon and I'll make sure that all the options will be installed.
The $UGII_BASE_DIR/nxplot/bin/pdf Folder does not exist on my system
Moti Eitan
If you don't have the PDF folder, then I don't believe it will work.
You're best bet is to try when you have NX8.5 installed.
Anthony Galante
PhoenxPLM
