Export structure to Excel-sheet with photos ?
Hello
Where to get a program that exports the assembly structure to Excel-sheet automatically and takes thumbnails/photos of each part automatically ?
Here is a screenshot used in my old workplace: ( How this was made anyone recognize ?)
  • Where can I find the program or code to lauch such commands that create the Excel ?
  • I know it is taken from somewhere from the internet but don't know where ?
12 REPLIES 12
Re: Export structure to Excel-sheet with photos ?
From native NX or TC-NX?
Native NX (not teamcenter)
Following is the journal code which creates the excel with images,ID,Description etc. similar to your requirement. It works fine in native NX.
Source: http://nxjournaling.com/content/export-assembly-excel-pictures-0
Option Strict Off
Imports System
Imports System.IO
Imports System.Windows.Forms
Imports System.Drawing
Imports System.Drawing.Imaging
Imports System.Runtime.InteropServices
Imports System.Collections.Generic
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.Assemblies
Imports NXOpenUI
Module BomToExcel
Public theSession As Session = Session.GetSession()
Public ufs As UFSession = UFSession.GetUFSession()
Public theUISession As UI = UI.GetUI
Public lw As ListingWindow = theSession.ListingWindow
Const xlCenter As Long = -4108
Const xlDown As Long = -4121
Const xlUp As Long = -4162
Const xlFormulas As Long = -4123
Const xlLeft As Long = -4131
Const xlAbove As Long = 0
Const xlWhole As Long = 1
Const xlByRows As Long = 1
Const xlNext As Long = 1
Const msoTrue As Long = -1
Const strPicFilesPath As String = "c:\partimages\"
Dim lngLevelStart(20) As Long
Dim colLevel As Integer = 1
Dim colImage As Integer = 2
Dim colID As Integer = 3
Dim colDescription As Integer = 4
Dim colQuantity As Integer = 5
Dim colParentChild As Integer = 6
Dim colParent As Integer = 7
Dim colBranchTop As Integer = 8
Dim colBranchCreated As Integer = 9
Private IsTcEng As Boolean = False
Dim lg As LogFile = theSession.LogFile
Private _notLoaded As New List(Of String)
Sub Main()
Dim dispPart As Part = theSession.Parts.Display
Dim workPart As Part = theSession.Parts.Work
Dim objExcel As Object
Dim objWorkbook As Object
Dim objWorksheet As Object
lg.WriteLine("")
lg.WriteLine("~~~~ Start of BomToExcel journal ~~~~")
lg.WriteLine("Timestamp: " & Now)
lg.WriteLine("")
'determine if we are running under TC or native
ufs.UF.IsUgmanagerActive(IsTcEng)
lg.WriteLine("TC running? " & IsTcEng)
Dim markId1 As Session.UndoMarkId
markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "journal")
Dim excelFileName As String
Dim excelFileExists As Boolean = False
Dim row As Long = 1
Dim column As Long = 1
'Allow the user to create a new excel file or add to an existing one.
Dim SaveFileDialog1 As New SaveFileDialog
With SaveFileDialog1
.Title = "Save BoM to Excel File"
.InitialDirectory = "Z:\NX Macros"
.Filter = "Excel files (*.xlsx)|*.xlsx|Macro enabled Excel files (*.xlsm)|*.xlsm|All files (*.*)|*.*"
.FilterIndex = 1
.RestoreDirectory = True
.OverwritePrompt = False
.FileName = (dispPart.ComponentAssembly.RootComponent.DisplayName).Replace("/", "_")
If .ShowDialog() = DialogResult.OK Then
excelFileName = .FileName
lg.WriteLine("Excel file name specified: " & .FileName)
Else
lg.WriteLine("SaveFileDialog1: user pressed cancel, journal exiting")
Exit Sub
End If
End With
'This function will not complain if the directory already exists.
System.IO.Directory.CreateDirectory(strPicFilesPath)
'lw.Open()
'create Excel object
objExcel = CreateObject("Excel.Application")
If objExcel Is Nothing Then
theUISession.NXMessageBox.Show("Error", NXMessageBox.DialogType.Error, "Could not start Excel, journal exiting")
lg.WriteLine("Could not start Excel, journal exiting")
theSession.UndoToMark(markId1, "journal")
Exit Sub
Else
lg.WriteLine("Excel started successfully")
End If
If File.Exists(excelFileName) Then
'Open the Excel file
excelFileExists = True
objWorkbook = objExcel.Workbooks.Open(excelFileName)
lg.WriteLine("Excel file: '" & excelFileName & "' exists, opening file")
Else
'Create the Excel file
objWorkbook = objExcel.Workbooks.Add
objWorkbook.SaveAs(excelFileName)
lg.WriteLine("Excel file: '" & excelFileName & "' does not exist, creating file")
End If
If objWorkbook Is Nothing Then
lg.WriteLine("Could not open/create specified Excel file: '" & excelFileName & "'")
lg.WriteLine("journal exiting")
theUISession.NXMessageBox.Show("Error", NXMessageBox.DialogType.Error, "Could not open Excel file: " & excelFileName & ControlChars.NewLine & "journal exiting.")
Exit Sub
Else
lg.WriteLine("objWorkbook created/opened successfully")
End If
'Add a new sheet so that previously exported BoMs are not affected
objWorksheet = objWorkbook.Worksheets.Add()
'Add Column Titles
objWorksheet.Cells(1, colLevel).Value = "Level"
objWorksheet.Cells(1, colImage).EntireColumn.ColumnWidth = 10
objWorksheet.Cells(1, colImage).Value = "Images"
objWorksheet.Cells(1, colID).Value = "ID"
objWorksheet.Cells(1, colDescription).Value = "Description"
objWorksheet.Cells(1, colQuantity).Value = "Quantity"
objWorksheet.Cells(1, colParentChild).Value = "Parent|Child"
objWorksheet.Cells(1, colParent).Value = "Parent"
objWorksheet.Cells.VerticalAlignment = xlCenter
lg.WriteLine("Column titles added")
Try
Dim c As ComponentAssembly = dispPart.ComponentAssembly
If Not IsNothing(c.RootComponent) Then
'Process 'root component' (assembly file)
Dim rootDispName As String = (c.RootComponent.DisplayName).Replace("/", "_")
lg.WriteLine("processing assembly file")
lg.WriteLine(" display name: " & c.RootComponent.DisplayName)
lg.WriteLine(" rootDispName: " & rootDispName)
lg.WriteLine("")
objWorksheet.Cells(2, colLevel).Value = 0
objWorksheet.Cells(2, colID).Value = rootDispName
If IsTcEng Then
objWorksheet.Cells(2, colDescription).Value = c.RootComponent.GetStringAttribute("DB_PART_NAME")
lg.WriteLine(" DB_PART_NAME: " & c.RootComponent.GetStringAttribute("DB_PART_NAME"))
Else
objWorksheet.cells(2, colDescription).Value = c.RootComponent.Prototype.OwningPart.Leaf
lg.WriteLine(" Part name: " & c.RootComponent.Prototype.OwningPart.Leaf)
End If
lngLevelStart(0) = 3
'Create a screenshot only if one does not already exist
If Not File.Exists(strPicFilesPath & rootDispName & ".jpg") Then
lg.WriteLine(" screenshot does not exist, creating: " & strPicFilesPath & rootDispName & ".jpg")
CreateCroppedNxScreenshot()
Else
lg.WriteLine(" screenshot exists, using: " & strPicFilesPath & rootDispName & ".jpg")
End If
lg.WriteLine(" calling reportComponentChildren(" & c.RootComponent.DisplayName & ", 1, objWorksheet)")
reportComponentChildren(c.RootComponent, 1, objWorksheet)
Dim partLoadStatus1 As PartLoadStatus
Dim status1 As PartCollection.SdpsStatus
status1 = theSession.Parts.SetDisplay(dispPart, False, False, partLoadStatus1)
partLoadStatus1.Dispose()
Else
'Process a piece part
End If
Catch e As Exception
theSession.ListingWindow.WriteLine("Failed: " & e.ToString)
lg.WriteLine("process root component error: ")
lg.WriteLine(" " & e.Message)
End Try
objWorksheet.Cells.EntireColumn.AutoFit()
'Some variables required within excel
Dim rngStart As Object
Dim rngEnd As Object
Dim intIndent As Single
Dim intLeft As Single
Dim intTopRow As Integer
Dim i As Integer
Dim j As Integer
Dim lngStart As Long
Dim lngLevel As Long
Dim lngLastRow As Long
intIndent = 6.75
lngLastRow = objWorksheet.Cells(2, colLevel).End(xlDown).Row
'####### Add pictures to excel structure ################
Dim strFileName As String
For i = 2 To lngLastRow
strFileName = strPicFilesPath & objWorksheet.Cells(i, colID).Value & ".jpg"
If File.Exists(strFileName) Then
With objWorksheet.Pictures.Insert(strFileName)
With .ShapeRange
.LockAspectRatio = msoTrue
If .Width >= .Height Then
.Width = objWorksheet.Cells(i, colImage).Width - 6
Else
.Height = objWorksheet.Cells(i, colImage).Width - 6
End If
objWorksheet.Cells(i, colImage).EntireRow.RowHeight = .Height + 6
End With
.Left = objWorksheet.Cells(i, colImage).Left + 3 + intIndent * objWorksheet.Cells(i, colID).IndentLevel
.Top = objWorksheet.Cells(i, colImage).Top + 3
.Placement = 1 'Move and Size
.PrintObject = True
End With
End If
Next i
'####### End Add pictures to excel structure ################
'####### Add groupings to excel structure ################
With objWorksheet.Outline
.AutomaticStyles = False
.SummaryRow = xlAbove
.SummaryColumn = xlLeft
End With
For j = 8 To 1 Step -1
lngStart = 0
'Loop through rows
lngLevel = Int(objWorksheet.Cells(i, colLevel).Value)
If lngLevel = j And lngStart = 0 Then
lngStart = i
ElseIf lngLevel < j And lngStart > 0 Then
objWorksheet.Rows(lngStart & ":" & i - 1).EntireRow.Group()
lngStart = 0
ElseIf i = lngLastRow And lngStart > 0 Then
objWorksheet.Rows(lngStart & ":" & i).EntireRow.Group()
lngStart = 0
End If
Next i
Next j
'####### End Add groupings to excel structure ################
'####### Add branches to excel structure ################
For i = objWorksheet.Cells(3, colBranchTop).End(xlDown).Row To 3 Step -1
intTopRow = objWorksheet.Cells(i, colBranchTop).Value
rngEnd = objWorksheet.Cells(i, colID)
intLeft = rngEnd.offset(0, -1).Left + intIndent * (rngEnd.IndentLevel - 0.5)
If objWorksheet.Cells(intTopRow, colBranchCreated).Value <> 1 Then
'This is the first line with that parent, so need to draw a vertical line
rngStart = objWorksheet.Cells(intTopRow, colID)
With objWorksheet.Shapes.AddLine(intLeft, CSng(rngStart.Top), intLeft, CSng(rngEnd.Top + rngEnd.Height / 2))
.Line.Weight = 1.5
.Line.ForeColor.RGB = 0
End With
objWorksheet.Cells(intTopRow, colBranchCreated).Value = 1
End If
'Draw a horizontal line
With objWorksheet.Shapes.AddLine(intLeft, CSng(rngEnd.Top + rngEnd.Height / 2), intLeft + intIndent / 2, CSng(rngEnd.Top + rngEnd.Height / 2))
.Line.Weight = 1.5
End With
Next i
objWorksheet.Cells(1, colLevel).EntireColumn.Delete()
objWorksheet.Cells(1, colParentChild).EntireColumn.Delete()
objWorksheet.Cells(1, colParent).EntireColumn.Delete()
objWorksheet.Cells(1, colBranchTop).EntireColumn.Delete()
objWorksheet.Cells(1, colBranchCreated).EntireColumn.Delete()
'####### End Add branches to excel structure ############
'lw.Close()
If excelFileExists Then
theUISession.NXMessageBox.Show("BoM to Excel Complete", NXMessageBox.DialogType.Information, "A new sheet has been added to the Excel file: " & excelFileName & ".")
Else
theUISession.NXMessageBox.Show("BoM to Excel Complete", NXMessageBox.DialogType.Information, "The Excel file: " & excelFileName & " has been created.")
End If
If _notLoaded.Count > 0 Then
lw.WriteLine("Warning: BOM information is incomplete!")
lw.WriteLine("The following components could not be loaded:")
For Each compName As String In _notLoaded
lw.WriteLine(" " & compName)
Next
End If
objWorkbook.Save()
objWorkbook.Close()
objExcel.Quit()
objWorksheet = Nothing
objWorkbook = Nothing
objExcel = Nothing
lg.WriteLine(" ~~~ End of BomToExcel journal ~~~ ")
lg.WriteLine(" timestamp: " & Now)
lg.WriteLine("")
End Sub
Sub reportComponentChildren(ByVal comp As Component, _
ByVal indent As Integer, ByRef xlsWorkSheet As Object)
lg.WriteLine("")
lg.WriteLine(" reportComponentChildren(" & comp.DisplayName & ", " & "indent: " & indent & ")")
lg.WriteLine(" component path: " & comp.Prototype.OwningPart.FullPath)
If Not LoadComponent(comp) Then
Return
End If
Dim compDispName As String = (comp.DisplayName).Replace("/", "_")
Dim childDispName As String
lg.WriteLine(" comp.DisplayName: " & comp.DisplayName)
lg.WriteLine(" compDispName: " & compDispName)
Dim strFindString As String
Dim intWriteRow As Integer
'Dim doSearch As Boolean = False
If lngLevelStart(indent) = 0 Then lngLevelStart(indent) = xlsWorkSheet.Cells(1, 1).end(xlDown).offset(1, 0).Row
lg.WriteLine(" lngLevelStart(" & indent.ToString & ") = " & lngLevelStart(indent).ToString)
For Each child As Component In comp.GetChildren()
childDispName = (child.DisplayName).Replace("/", "_")
lg.WriteLine(" *processing child component: " & child.Prototype.OwningPart.Leaf)
lg.WriteLine(" childDispName: " & childDispName)
'Search for Parent|Child to see if it already exists.
strFindString = compDispName & "|" & childDispName
lg.WriteLine(" strFindString = " & strFindString)
'On Error Resume Next
Dim searchRange As Object = Nothing
Dim foundRange As Object = Nothing
Dim lngFoundInRow As Long = -1
Try
lg.WriteLine(" xlsWorkSheet.Cells(" & indent.ToString & ", " & colParentChild.ToString & ").Value = " & """" & xlsWorkSheet.Cells(lngLevelStart(indent), colParentChild).Value & """")
If xlsWorkSheet.Cells(lngLevelStart(indent), colParentChild).Value = "" Then
'no data entered to search yet
lg.WriteLine(" no data available for search")
Else
If xlsWorkSheet.Cells(lngLevelStart(indent), colParentChild).Offset(1).Value = "" Then
'only 1 value entered
searchRange = xlsWorkSheet.Cells(lngLevelStart(indent), colParentChild)
doSearch = True
lg.WriteLine(" number of rows available for search: " & searchRange.Rows.Count.ToString)
Else
'2 or more values entered, select them all
searchRange = xlsWorkSheet.Range(xlsWorkSheet.Cells(lngLevelStart(indent), colParentChild), xlsWorkSheet.Cells(lngLevelStart(indent), colParentChild).End(xlDown))
doSearch = True
End If
End If
lg.WriteLine(" doSearch = " & doSearch.ToString)
If doSearch Then
foundRange = searchRange.Find(strFindString, , xlFormulas, xlWhole, xlByRows, xlNext, False, , )
End If
If IsNothing(foundRange) Then
lg.WriteLine(" foundRange is Nothing")
Else
lngFoundInRow = foundRange.Row
lg.WriteLine(" lngFoundInRow = " & lngFoundInRow.ToString)
End If
Catch ex As Exception
lg.WriteLine(" ** excel search error")
lg.WriteLine(" ** " & ex.Message)
End Try
'If Not lngFoundInRow = 0 Then
If lngFoundInRow > -1 Then
lg.WriteLine(" found in row: " & lngFoundInRow.ToString & ", adding to quantity")
xlsWorkSheet.Cells(lngFoundInRow, colQuantity).Value = xlsWorkSheet.Cells(lngFoundInRow, colQuantity).Value + 1
lg.WriteLine(" new quantity: " & (xlsWorkSheet.cells(lngFoundInRow, colQuantity).Value).ToString)
lg.WriteLine("")
Else
lg.WriteLine(" not found, creating new record")
'Add new component or subassembly
intWriteRow = xlsWorkSheet.Cells(1, 1).end(xlDown).offset(1, 0).Row
xlsWorkSheet.Cells(intWriteRow, colLevel).Value = indent
xlsWorkSheet.Cells(intWriteRow, colID).Value = childDispName
xlsWorkSheet.Cells(intWriteRow, colID).IndentLevel = indent
If IsTcEng Then
xlsWorkSheet.Cells(intWriteRow, colDescription).Value = child.GetStringAttribute("DB_PART_NAME")
Else
xlsWorkSheet.cells(intWriteRow, colDescription).Value = child.Prototype.OwningPart.Leaf
End If
xlsWorkSheet.Cells(intWriteRow, colQuantity).Value = child.GetIntegerQuantity
xlsWorkSheet.Cells(intWriteRow, colParentChild).Value = strFindString
xlsWorkSheet.Cells(intWriteRow, colParent).Value = compDispName
xlsWorkSheet.Cells(intWriteRow, colBranchTop).Value = lngLevelStart(indent)
If Not File.Exists(strPicFilesPath & childDispName & ".jpg") Then
lg.WriteLine(" screenshot does not exist, creating: " & strPicFilesPath & childDispName & ".jpg")
Dim Part1 As Part
If IsTcEng Then
Part1 = CType(theSession.Parts.FindObject("@DB/" & child.GetStringAttribute("DB_PART_NO") & "/" & child.GetStringAttribute("DB_PART_REV")), Part)
lg.WriteLine(" Part1: " & "@DB/" & child.GetStringAttribute("DB_PART_NO") & "/" & child.GetStringAttribute("DB_PART_REV"))
Else
Part1 = child.Prototype.OwningPart
lg.WriteLine(" Part1: " & Part1.FullPath)
End If
status1 = theSession.Parts.SetDisplay(Part1, True, True, partLoadStatus1)
If child.GetNonGeometricState OrElse child.IsSuppressed Then
'if .GetNonGeometricState = True, comp is set as 'non-geometric'
'skip screenshot
Else
End If
Else
lg.WriteLine(" screenshot exists, using: " & strPicFilesPath & childDispName & ".jpg")
End If
lg.WriteLine("")
reportComponentChildren(child, indent + 1, xlsWorkSheet)
'On Error GoTo 0
End If
Next
lg.WriteLine(" End of processing component: " & comp.DisplayName)
lg.WriteLine("")
End Sub
Public Function GetUnloadOption(ByVal dummy As String) As Integer
Return Session.LibraryUnloadOption.Immediately
End Function
Sub CreateCroppedNxScreenshot()
lg.WriteLine("CreateCroppedNxScreenshot")
'Create a JPG screenshot ###################
Dim displayPart As Part = theSession.Parts.Display
theSession.Preferences.ScreenVisualization.FitPercentage = 100
'turn triad off
theSession.Preferences.ScreenVisualization.TriadVisibility = 0
'turn WCS off
displayPart.WCS.Visibility = False
'turn off view/model names display and borders
displayPart.Preferences.NamesBorderVisualization.ShowModelViewNames = False
displayPart.Preferences.NamesBorderVisualization.ShowModelViewBorders = False
'Trimetric view
displayPart.ModelingViews.WorkView.Orient(NXOpen.View.Canned.Trimetric, NXOpen.View.ScaleAdjustment.Fit)
'Hide datums and sketches
Dim numberHidden As Integer
numberHidden = theSession.DisplayManager.HideByType(DisplayManager.ShowHideType.Datums, DisplayManager.ShowHideScope.AnyInAssembly)
numberHidden = theSession.DisplayManager.HideByType(DisplayManager.ShowHideType.Sketches, DisplayManager.ShowHideScope.AnyInAssembly)
'Set the filename
'Dim prtJpg As String = strPicFilesPath & displayPart.FullPath & ".jpg"
Dim prtJpg As String = strPicFilesPath & displayPart.Leaf & ".jpg"
'Create the image
ufs.Disp.CreateImage(prtJpg, UFDisp.ImageFormat.Jpeg, UFDisp.BackgroundColor.White)
'End Create a JPG screenshot ###################
' Create a new bitmap.
Dim bmp As New Bitmap(prtJpg)
' Lock the bitmap's bits.
Dim rect As New Rectangle(0, 0, bmp.Width, bmp.Height)
Dim bmpData As System.Drawing.Imaging.BitmapData = bmp.LockBits(rect, Drawing.Imaging.ImageLockMode.ReadOnly, bmp.PixelFormat)
' Get the address of the first line.
Dim ptr As IntPtr = bmpData.Scan0
' Declare an array to hold the bytes of the bitmap.
' This code is specific to a bitmap with 24 bits per pixels.
Dim bytes As Integer = Math.Abs(bmpData.Stride) * bmp.Height
Dim rgbValues(bytes - 1) As Byte
Dim intStartRow As Integer
Dim intStartCol As Integer
Dim blnFoundPixel As Boolean = False
Dim x As Integer
Dim y As Integer
Dim cropTop As Integer
Dim cropBottom As Integer
Dim cropLeft As Integer
Dim cropRight As Integer
Dim cropWidth As Integer
Dim cropHeight As Integer
Dim thumbWidth As Integer = 200
Dim thumbHeight As Integer = 200
Dim resizeWidth As Integer
Dim resizeHeight As Integer
' Copy the RGB values into the array.
System.Runtime.InteropServices.Marshal.Copy(ptr, rgbValues, 0, bytes)
'Loop through from top
For y = 0 To bmp.Height - 1
intStartRow = y * Math.Abs(bmpData.Stride)
For x = intStartRow To intStartRow + (bmp.Width - 1) * 3 Step 3
If rgbValues(x) = 255 And rgbValues(x + 1) = 255 And rgbValues(x + 2) = 255 Then
Else
cropTop = y - 2
If cropTop < 0 Then cropTop = 0
blnFoundPixel = True
Exit For
End If
Next
If blnFoundPixel Then Exit For
Next
If Not blnFoundPixel Then
'This is a completely white image
cropTop = 0
'cropBottom = bmpData.Height
cropBottom = thumbHeight
cropLeft = 0
'cropRight = bmpData.Width
cropRight = thumbWidth
Else
'Check from the other directions
'Loop through from bottom
blnFoundPixel = False
For y = bmp.Height - 1 To 0 Step -1
Else
cropBottom = y + 2
If cropBottom > bmp.Height - 1 Then cropBottom = bmp.Height - 1
Exit For
End If
Next
Next
'Loop through from left
For x = 0 To bmpData.Width - 1
intStartCol = x * 3
For y = intStartCol To rgbValues.Length - 1 Step Math.Abs(bmpData.Stride)
If rgbValues(y) = 255 And rgbValues(y + 1) = 255 And rgbValues(y + 2) = 255 Then
Else
cropLeft = x - 2
If cropLeft < 0 Then cropLeft = 0
Exit For
End If
Next
Next
'Loop through from right
For x = bmpData.Width - 1 To 0 Step -1
intStartCol = x * 3
Else
cropRight = x + 2
If cropRight > bmpData.Width - 1 Then cropRight = bmpData.Width - 1
Exit For
End If
Next
Next
End If
' Unlock the bits.
bmp.UnlockBits(bmpData)
' Crop the white space from around the image
cropWidth = cropRight - cropLeft
cropHeight = cropBottom - cropTop
Dim cropRect As New Rectangle(cropLeft, cropTop, cropWidth, cropHeight)
Dim cropBmp As New Bitmap(cropWidth, cropHeight)
cropBmp = bmp.Clone(cropRect, bmp.PixelFormat)
' Resize the image to required thumbnail size (maintaining aspect ratio)
If cropWidth / thumbWidth > cropHeight / thumbHeight Then
resizeWidth = thumbWidth
resizeHeight = CInt(thumbWidth * cropHeight / cropWidth)
Else
resizeHeight = thumbHeight
resizeWidth = CInt(thumbHeight * cropWidth / cropHeight)
End If
bmp.Dispose()
' Save the resized image
Using OriginalImage As Image = cropBmp
Using ResizedImage As New Bitmap(OriginalImage, resizeWidth, resizeHeight)
ResizedImage.Save(prtJpg, Drawing.Imaging.ImageFormat.Jpeg)
End Using
End Using
cropBmp.Dispose()
lg.WriteLine("Exiting screenshot subroutine")
lg.WriteLine("")
End Sub
Private Function LoadComponent(ByVal theComponent As Component) As Boolean
lg.WriteLine("Sub LoadComponent()")
Dim thePart As Part = theComponent.Prototype.OwningPart
Dim partName As String = ""
Dim refsetName As String = ""
Dim instanceName As String = ""
Dim origin(2) As Double
Dim csysMatrix(8) As Double
Dim transform(3, 3) As Double
Try
If thePart.IsFullyLoaded Then
'component is fully loaded
Else
'component is partially loaded
End If
lg.WriteLine(" component: " & theComponent.DisplayName & " is already partially or fully loaded")
lg.WriteLine(" return: True")
lg.WriteLine("exiting Sub LoadComponent()")
lg.WriteLine("")
Return True
Catch ex As NullReferenceException
'component is not loaded
Try
lg.WriteLine(" component not loaded, retrieving part information")
ufs.Assem.AskComponentData(theComponent.Tag, partName, refsetName, instanceName, origin, csysMatrix, transform)
lg.WriteLine(" component part file: " & partName)
Dim theLoadStatus As PartLoadStatus
theSession.Parts.Open(partName, theLoadStatus)
If theLoadStatus.NumberUnloadedParts > 0 Then
If theLoadStatus.NumberUnloadedParts > 1 Then
lg.WriteLine(" problem loading " & theLoadStatus.NumberUnloadedParts.ToString & " components")
Else
lg.WriteLine(" problem loading 1 component")
End If
Dim allReadOnly As Boolean = True
For i As Integer = 0 To theLoadStatus.NumberUnloadedParts - 1
lg.WriteLine("part name: " & theLoadStatus.GetPartName(i))
lg.WriteLine("part status: " & theLoadStatus.GetStatus(i))
If theLoadStatus.GetStatus(i) = 641058 Then
'read-only warning, file loaded ok
Else
'641044: file not found
allReadOnly = False
If Not _notLoaded.Contains(partName) Then
_notLoaded.Add(partName)
End If
End If
lg.WriteLine("status description: " & theLoadStatus.GetStatusDescription(i))
lg.WriteLine("")
Next
If allReadOnly Then
lg.WriteLine(" 'read-only' warnings only")
Return True
Else
'warnings other than read-only...
lg.WriteLine(" return: False")
lg.WriteLine("")
Return False
End If
Else
lg.WriteLine(" component(s) loaded successfully")
lg.WriteLine("")
Return True
End If
Catch ex2 As NXException
lg.WriteLine(" Load error: " & ex2.Message)
lg.WriteLine(" error code: " & ex2.ErrorCode)
lg.WriteLine("")
If ex2.Message.ToLower = "file not found" Then
End If
End If
Return False
End Try
Catch ex As NXException
'unexpected error
lg.WriteLine(" Error in Sub LoadComponent: " & ex.Message)
lg.WriteLine("")
Return False
End Try
End Function
End Module
How to launch these "journal codes" ?
- Where can I input this journal code ?
You need to open the assembly first and then run this vb code from here...
Just to add the response of Kapil
File > Preferences > User Interface (Ctrl+2) > Tools > Journal
Make sure that 'Visual Basic' is selected.
Alt+F11
Copy ans paste the code, Click on 'Play' icon
What is the difference between "NX Journal" and "NX macro" ?
A journal program will run the actual commands that are called out and will work from version to version of NX. A macro will just use menu picks, like 4th item on 2 second dropdown and may or may not work from version to version.
Scott
Also note that you can customize your UI so that you can launch a journal at the click of a button:
http://nxjournaling.com/content/start-journal-custom-button
If you want to roll out the customization to everyone that uses CAD, MenuScript would be a better choice; but the customization shown above is a good way to start with customization.
