Re: Export structure to Excel-sheet with photos ?
Image size is too small. Tried to change these size 200 originally to 400. No diffrence ?
- How to make them bigger ?
Dim thumbWidth As Integer = 400
Dim thumbHeight As Integer = 400
The column width and row height also play a part. Excel scales down the image to fit in the cell.
How would you modify this code to add columns for the assigned material and calculated weights?
