Expression location problem
Builder
Builder
Hello experts,
i have query in NX,
i have many type of expression in my sketch, some times i confused to find the location of expression where is that, for eg. i created expression given name p79 ,now like image my sketch & more expression,,now i have to find p79,,but i cant,,,
so is there any option to find or filter expression as i want,,, where is my expression located
thanks
Warm Regards
Thomas Roman
Machine Designer
4 REPLIES 4
Re: Expression location problem
In NX11 you can use the Sketch Relations Browser.
This has not a option to find a dimension based on Name.
You can see what constrains/dimensions are related to the lines and from here you can use the " fit view to selection" to locate the dimensions/Constrain.
Nice enhancement for the future would be that there is here also the expression name placed instant of only the kind of dimension in combination with the line numbers.
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
Hi @Thomas_Roman,
Select the sketch in the part navigator > RMB > Edit Parameters.
Now select any expression, either user defined or NX generated and it will be highlighted in the UI display.dim.png
Ganesh Kadole
Thanks @Thomas_Roman
Your correct tagging / Description has solved my problem too
Builder
Builder
thanks@Ganesh_Kadole & ruud_vandenbrand
thanks for the help guys again,,,
i appreciated for that
& welcome@sathya for same.......
Warm Regards
Thomas Roman
Machine Designer
