Expressions
I am trying to familiarize myself with as much Expression knowlege as I can. I was wondering if there is a published list or something out there that lists all the available syntex, (and there definitions) that can be used in NX Expressions?
Example the different Math Operators and or Functions and String Operators and or Functions. Also things like how you can use "If, Than or Else". Thank you very much in advance.
Re: Expressions
start here
https://docs.plm.automation.siemens.com/tdoc/nx/11.0.1/nx_help/#uid:xid1128417:index_modeling:expres...
use the right-side links for more information.
Tip: Probably the most important thing is to get the units right, first.
