FATAL ERROR NX 10
Hello all,
One of my customer is facing an fatal error issue from past few days and he has enough system config to run NX. Attaching the files below can anyone tell me whats the solution for this>fatal error.JPGINFO.JPG
Re: FATAL ERROR NX 10
Contact GTAC.  You could also pull the system log file and look in there for clues.  Is this duing a update, opening a file?
