FEA
Hello all. Just a quick question that hopefully someone can answer. I am running Siemens NX 10 on a windows 10 machine. Modeling is not an issue but i get some major lag when rotation my model in simulation once my mesh is applied. When i solve my FEA and it list my system configuration ( i7 6500, 8gb ram etc.) it states I am using Windows 8 as my OS. Could this be the cause of or have anything to do with my experienced lag? Am i missing some kind of patch or update? Cheers. Luc
Re: FEA
Hello @Nozzle,
If it's the graphics that is causing the problem, then my first guess would be, check your graphic drivers.
Have a look here for the certified drivers. Or just grap the latest driver from the Graphics Card vendor's website.
Hope this helps.
Kind regards,
Dennis
Dennis de Brouwer
Application Support Engineer
GTAC EMEA - Siemens Industry Software
