Face Blend
Ciao,
where I find in NX11 the option shown il the attached pictures?
thanks
Cesare
5 REPLIES 5
Re: Face Blend
On the Home tab, feature group, edge blend dropdown.
The command was renamed to 'Two Face'
Re: Face Blend
I look for the option 'coincident curve' and 'tangent curve' on the first and second set of faces.
Re: Face Blend
Expand the Width group in the dialog box
Re: Face Blend
Thank you RonY,
pheraps I'm 'thick as a brick', but I don't find the option.
Ciao
Re: Face Blend
Hi Cesare,
In the Face Blend interface, in the Cross Section group, set Radius Method = Limit Curve. Then in the Width Limits group select a tangent limit curve.
Eric
