Failed to export assembly data to excell
Hello everyone,
When I want export my assembly data to excell, I get an error "Failed to create new excell workbook".
I click right button on assembly navigator and choose "Export to spreadsheet".
Does anyone know what is solution of that issue?
Best regards,
Jack
Re: Failed to export assembly data to excell
Hi @Jack1,
What version of NX and excel are you using?
Ganesh
I have NX6 and Excell 2013 - 32bit
Hi @Jack1,
I have NX 6 (6.0.5.3 MP12) on windows 7 64-bit system and Microsoft Office 2013. It works fine. I don't know if this issue related to the 32/64 bit system. @BenBroad could give you the exact suggestion/information about it.
Ganesh
Hi @Jack1,
Do any other spreadsheet functions work?  Can you open the Gateway/Modeling/Part Family spreadsheets?  Does "Spreadsheet Edit" work from the Expressions dialog?
Did this ever work?  If it did, what have you installed/upgraded/changed recently that might have affected your NX/Excel integration?
Regards, Ben
Did you un-install any NX versions?  Could be the ug.xla file got removed...
