Fast way to rename part in NX11+TC11 ?
Hello
How to rename part, part revision and model all in one in NX11+TC11 ?
I now do it like this:
1. In part main TC11 MB3 -> Edit properties -> Name...
2. In part revision TC11 MB3 -> Edit properties -> Name...
3. In 3D part itself TC11 MB3 -> Edit properties -> Name...
I have to change the name in 3 seperate places.
Is there a way to change all at once ?
Re: Fast way to rename part in NX11+TC11 ?
Not sure if it works for UGMASTER/UGPART dataset, but select (Ctrl+item,item revision,dataset) all of them > MB3 > Edit Properties. Edit the name for each object and accept the changes.
Ganesh
Hi @GaneshKadole,
It does work.  Once the Common Modifiable Properties dialog opens, you then have to multiselect the Item, Item Revision and Dataset under the Name column before you enter a new Name.
Regards, Ben
