Fatal Error in NX10
Builder
Builder
After last MP for NX10.0.3 (MP04), NX radomly crashing with error:
What is the problem?
9 REPLIES 9
Re: Fatal Error in NX10
That's a relatively generic error. I would suggest calling your local GTAC office:
http://www.plm.automation.siemens.com/en_us/support/gtac/gtac-hours.shtml
Regards, Ben
NX (v17 - 1876) | Teamcenter (9 - 12)
I had the same problem, mine seemed pretty consistent when closing windows or files.  Sometimes with saving, sometimes without.  I worked around it by always saving before closing.
I called GTAC and got a big time run-around because I didn't have an optimal system off the special list.  Terribly disappointing way to treat a customer.
Could you let us know more about your specific configuration? Platform/OS/hardware/etc? Was it the same case as above where problems didn't start occurring until after installing the latest NX10.0.3 MP?
Regards, Ben
I am currently on 10.0.3.5.  I didn't make a direct link between the installation of that version and the problems, but they did appear around that time.  My problem is more intermittent (it doesn't happen all the time, seems close to 50% of the time I close a file).
Sent you a private message.
Regards, Ben
Hi Ben,
Curious to see what came of this as we are experiencing the same issue and you sent a private message..
Were you able to find a root cause of this issue? If so, could you please share it?
thanks,
Jake
Hi Jake,
Having matched the error in Steve's syslog with an existing, closed PR, I suggested that he install a maintenance pack for his current version in which the PR's problem was fixed.
If you're experiencing similar problems, please open an IR with GTAC and provide any syslogs from those sessions.
Regards, Ben
Thank you Ben for your response!
Jake
Have not had the error since the update.  Running NX11 now, and no issues here either.
