Re: File path on drawing
Hi @AtulL3d,
I've attached an NX 9 part file for you to review and see how this is created as an expression.
Hope this helps.
Regards, Ben
NX (v17 - 1872) | Teamcenter (9 - 12)
Thank you @BenBroad.
Just checked it out.
Exactly what I was looking for. Paul S.
{Paul Schneider}, {CNC Programmer}, {DRT-Rochester}
Production: {NX11.0.2,MP5, NX12.0.2, MP4}
HI BenBroad,
Now it is working in NX 12.it was happen due to i copied the expression from browser paste directly to the expp chart.
Thanks for giving the prt file.
thank you.
