File saving with methodology
hello,
I have saved a file with name ENG_000001 at local folder (Let it be a blank file).
Then if I try to save a new file in same location with name ENG_000002 (blank file), then NX is throwing an error as "File already exsists".
It can still be saved in same location and with same name by trying to save it in a new session.
But the problem arises when I open ENG_000001 in NX,
then try to open ENG_000002,
it throws an error which say:-
"You choose to open ----(location\ENG_000001)----
Another version of same part is already loaded ----(location\ENG_000002)----
To see the current loaded part, choose Change Display Part.
If you want to open a different part, choose Back to return
to open Part Dialogue.
If you still want to open the part, Choose cancel and
close the conflicting part first.
Do anyone has any idea how to rectify this issue.
Re: File saving with methodology
can you make a movie of the steps that you preform?
Alt+F5 start record movie of NX window
Alt+F7 to stop recording.
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
You have "Part Name Versions" defined in your "customer defaults".
Remove them and NX will no longer recognize your partfiles as versions of each other.
Check menu "File / Utilities / Customer Defaults", then "Assemblies / Site Standards / Part Name Versions" and the definitions in "Full Part File Name Format" and below
