Fill empty area of a body
Hello all
I want to fill voids or empty area of the body in attached file (taken as photograph).  I tried surface fill and subtract geometry from a random domain but I failed. So could you give any idea
thnks
Re: Fill empty area of a body
Did you try 'Delete Face' command?
Ganesh
have you tried a N sided surface, I have had this work in places that Fill surface would not work.
How can I apply it ? Region face ?
I tried but did not work
The part you are working is a sheet body?  Is your goal to turns this into a solid body?  thanks
Not sheet body but closed volume body
Ok that makes more sense, I would extrude the outside profile down into the part about .05 or so.  In the simplify assembly it gives you the option to close up holes.  I would do it manually for all three of the big pockets bores on each end.  Before using the simplify assembly command.     Then use the simplify assembly to delete the internal surfaces.
simplify assembly only helps to cover holes. My part do not have any holes
