Re: Fill empty area of a body
Check this short video out, I do not if this helps.
You have to have a advance assembly license for the simplify assembly.
My part has a lot of curvature and simplify assembly only helps to fill the holes. I tried but It failed.  Any help would be great
Hi Scorp,
A dumb question from my side...
Is this body an unparametric body? If yes then it will not be a straight forward process (Delete face as suggested by @GaneshKadole and other manual work will be required...you can infact delete the blend faces quite effectively using proper selection filters).
If the model is a complete parametric one then you can go up in your feature history make the main primitive body (without any pocket/blends etc.) a current feature and use Extract Body.
Best Regards
Kapil
hello
I tried delete face but gives error as there are curves on the part. I think delete face is not useful. I tried covering the body with extrude than subtract it but nothing came up
@scorp wrote:
hello
It would be easy to help you if you can upload that particular part file here.
