Finding and Selecting Suppressed Components
Does anyone know of a way to find and select all the suppressed components within an entire assembly structure?
The Unsuppress Component command under the assembly tab basically does that, but if you complete the function (which of course undoes the suppression of the component) or exit the function the selections are removed.
Has anyone written a journal file that would accomplish this? I looked through the Solution center under GTAC and found two that generate lists, but I wouldn't know how to change those to have them select the components.
1) https://solutions.industrysoftware.automation.siemens.com/view.php?sort=desc&q=Suppressed+Components...
2) https://solutions.industrysoftware.automation.siemens.com/view.php?sort=desc&q=Suppressed+Components...
Thanks!
