Fix All Components of an Assembly
I'm working with imported assembly steps files that have more than 100 components and I need to fix all of the components, is there a way to do it without fixing one by one? Perhaps a macro or something easier and faster?
thanks
Re: Fix All Components of an Assembly
@JohnRBakerposted a journal on eng-tips a while back that may be of use to you.
the Bond constraint and then apply a Fix constraint was exactly what I needed, thanks!
