Fixing a circular redundancy
Honored Contributor
Honored Contributor
User has an assembly, that  he inherited from a former employee.  He has been breaking active wave links, but is still getting a circular renundancy message.  My thought is the circularity is using some other assembly to make the connection, or something.
We use Teamcenter, and have the Wave Control license for NX, but so far we have not found a good "map" to help define what is going on.  Any additional thoughts?
-Dave
3 REPLIES 3
Re: Fixing a circular redundancy
Did you check the relations browser? Any hints there?
Is the message specifically about wave links? I've seen assemblies where the components/subassemblies had circular component references (nothing to do with wave links). The usual troubleshooting process is to load the assembly "structure only" then open components one by one until you get the message. Take a close look at the component that caused the message.
Hi @DaveK,
Review the user's NX syslog - it should list an indented cyclic structure (before the entry where the message was raised) which might help you identify what's causing the problem.
Regards, Ben
Honored Contributor
Honored Contributor
@BenBroad our reason for the "wave control" license, was to use the "Associativity Manager" for this type of thing, and so far it hasn't worked in the past.  Am I misunderstanding the use of this tool?  (I also need to get our license for it updated, IF it will be of use like this)
-Dave
