Front / side / top views are not correctly aligned (assembly)
I've always started sketching parts by lining them up with one of the front, side, etc, planes. I've created an assembly and lined the first part up with absolute origin. This worked without problem and the drafting views were all as should be.
Now somehow, without knowing what I did wrong, the drafting views are angled. Is there a way of restoring / realigning the views?
Re: Front / side / top views are not correctly aligned (assembly)
Check the angle value in view settings (Settings > Common > Angle) whether its zero.
Ganesh
Hi, The angle settings have been unchanged (still at zero). In model space the views are not aligned as they were anymore either. Front view is not perpendicular to a flat plate (for example). It's slightly angled.
you can save view in modeling and use as per your requrment just like Top, front, etc. and that can be used as per your requrment in drafing to place it by basic view.
RRG
