GD&T validation in Drafting
I would like to know whether there is any method or tool to find the GD&T call out that i have given is valid ( as per stnd) .
5 REPLIES 5
Re: GD&T validation in Drafting
You can use some PMI GD&T checks in checkmate for SYNTAX and SYNTACTIC. The syntactic check tells you if there is some issue with the GD&T symbol used in the PMI for ex..if i use flatness symbol instead of a profile on a slightly curved surface...it shows an issue.
Best Regards
Kapil Sharma
But it is not working in drafting. The check skipped all the gd and t callouts
Checks 'PMI GD&T Semantic Validity' and 'PMI GD&T Syntactic Validity' works on the PMI's created in the modeling application not the drafting.
You can create, validate those in the modeling application and inherit them in drafting views.
Hi Kiran,
Sorry for a late reply... i should have checked that you asked for the GD&T checks in drafting.... Unluckily i am not aware of any OOTB check for GD&T in drafting so if possible you can follow the same procedure as Ganesh explained.
Best Regards
Kapil
