Gear Design
Does any body know what kind of modul to make design gear and crank shaft in NX?
Thank you in advance
Dadang
Re: Gear Design
Read GC_Toolkits_GearModeling.pdf in ......UGII_BASE_DIR\LOCALIZATION>prc>documents
Up to version 7.5 this module does not require any license.
Ciao
Re: Gear Design
Set Environmental Variables
name = UGII_COUNTRY
value = PRC
Re: Gear Design
Dear jahnsen and cesare,
Thanks for your informations .
so we don't need any license to use gear modeling. How about cam modeling? does any solution in NX to make cam modeling like gear modeling?
Dadang
Re: Gear Design
CAM? you mean machining?
you need license for it. i think it is mach3? NX 12450 if I am not mistaken.
Re: Gear Design
Dear Jahnsen,
it's not machining proces, but to creating cam part (one of component in the otomotive part, generally cam is assembled by shaft.
Re: Gear Design
Re: Gear Design
Re: Gear Design
please look at the picture above
Re: Gear Design
never heard of an application for that.
but for this kind of models, I think PTS will help you.
see link below.
http://www.plm.automation.siemens.com/en_us/products/nx/for-design/product-design/template-based.sht...
