Gear ufunc program
Honored Contributor
Honored Contributor
From one of the old threads on gears, John Baker shared these programs.  The GRIP I got to run, but not the user function.  What is the trick?
I've gone File, Execute, NX Open, browse to the .dll, and I am greeted with this error:
Any newer gear programs out there?  @FrankSwinks ever finish his?
-Dave
13 REPLIES 13
Re: Gear ufunc program
Guessing...
The ufunc progam is not compiled/linked for your version of NX.
GRIP has been on life support for so long that old GRX files will (usually) still work.
There is a gear program in the GTAC knowledge center (a.k.a. UGANSWER). This would be a much more modern starting point than either grip or user function.   https://solutions.industrysoftware.automation.siemens.com/view.php?sort=desc&q=gear&dt=nx-api&file_t...
Path = nx_api4685.zip
   Date      Time    Attr         Size   Compressed  Name
2012-06-01 13:08:44 ....A          904          356  Gear.sln
2013-01-08 18:30:18 .....         7846         2452  Gear.vb
2012-06-01 13:38:24 ....A         6272         1567  Gear.vbproj
2012-06-15 17:02:28 ....A       393005       380348  Read Me.pdf
2012-06-01 13:05:26 ....A          438          222  Unload.vb
                                408465       384945  5 files, 0 folders
Mark Rief
Retired Siemens
Yes I am still working on a much updated spur gear program. It will include trochoid fillet and addendum modification. Unfortunately my computer is in for repair/service so I cannot do anything at this time.
Frank Swinkels
Honored Contributor
Honored Contributor
My money is on "operator error", but I didn't have much luck.  I ran the Gear.vb as a journal, and got a few errors.  Does it need to be compiled for Win64, or?
-Dave
Dave -
Did you download the ZIP file and read the "read me.pdf"?
Honored Contributor
Honored Contributor
Yeah, but I never got the GUI to input anything, just the errors.
-Dave
Do you have a SNAP and blockstyler license? It looks like they will be required to run the code.
Honored Contributor
Honored Contributor
I don't see anything about SNAP in our configuration report.
-Dave
Attached is an update for gear_model2.  This is built for NX9 and has been signed.  It does need to have the dialog file correctly located.  Because it is only an update for the old program it does not include the features I am currently working on.
Hope this is of some use.
Frank Swinkels
