Generate Shadows
Recently upgraded from NX6 to NX10. The "generate shadows" option is no longer available within the image preferences dialog in the Studio Render application in NX10 - as shown in the attached image.
Would anyone know where this generate shadow option exists in NX10?
Thank you.
3 REPLIES 3
Re: Generate Shadows
It was removed in NX10 as part of the retirement path for the High Quality Image command.
Was your intent to turn off the shadows?
Thanks for the reply regarding the retirement path solution.
User who brought this question forward is aware of where the shadow on/off settings are located.
Shadows can still be enabled/disabled in NX10 by editing the lights.
Regards, Ben
