Get last string character of part name into expression
Siemens Pioneer Siemens Pioneer
Siemens Pioneer
Dear Experts,
 I'm searching for the method/ solution of getting the last character of part name ( for example: name= 1L09FZ) in expression?
The use case is the following: if the last character of the part name is "Z" in the graphic viewer must be displayed "Fahrzone" text else "Weiche".
Thx,
Ana
3 REPLIES 3
Re: Get last string character of part name into expression
Hi @agherla ,
Please try below. This might help.
Amol
Hi @agherla ,
Below method of defining expressions will give last character of part name irrespective of string length.
Hope it helps.
Amol
@agherla , another approach with single expression which will work for any part:
if(subString((substring(ug_askCurrentWorkPart(),1,(length(ug_askCurrentWorkPart())-4))),length(ug_askCurrentWorkPart())-4,length(ug_askCurrentWorkPart()))="Z")("Fahrzone")else("Weiche")
Just create new expression with above formula.
Samadhan
GTAC | NX Help: NX1102 | NX1202 | NX1847
Please mark post as an "Accepted Solution", if it answers your question/is more helpful!
