Getting same settings for new install
We are just about to go from NX7.5 to NX10.0, How do I make sure that all the drafting settings like line density and dimensions always being horizontal are kept the same as before?
Re: Getting same settings for new install
How did you set your settings?
If its in your template you can reuse them in nx10
For the customer defaults you can import the old customer defaults en drafting standaards in NX 10.
Tip here is to import the customer defaults also into your drafting standaards because in the time some settings are moved to the drafting standaards.
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
I have created a new template part for NX10.0.
How do I import the customer defaults from NX7.5 into the Drafting standards(preferences) in NX10.0
First import the defaults of 7.5 into the defaults of 10.
Open the template go to the drafting precerences and the ingetikt from defaults
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
The best way to import the customer defaults part can be found here.
Export and Import Customer Defalts
Scott
