Global Shaping
Hello!
How do I get rid of this?
Re: Global Shaping
Sounds like either your input body or your tool body is a Convergent Body?  Is that right?
Taylor Anderson
NX Product Manager, Knowledge Reuse and NX Design
Tel: +1 (602) 441-0683
taylor.anderson@siemens.com
Re: Global Shaping
Hello Taylor!
The cause of this problem was a spline with grade * 1 * grade * 3 * and the message disappeared. Problem solved. I'm using Global Shaping and for some reason I do not know that happened.
Thanks for the reply, my friend!
Re: Global Shaping
Not sure if my comment helped at all, but I'm glad you got it figured out.  :-D
Thanks!
Taylor Anderson
