Graphics
Is there a reccommended graphics driver or card reccomended for NX 10.
Seems like i am using view-layout-update display way too frequently.
current graphics card - NVIDIA Quadro K4000 (Version 7.5.780.0) set to 1920 x 1200 display 60Hz 32bit
Re: Graphics
Hello @RTD,
Not just one recommended Graphics Card, but a comlete list of certified Cards you can find on our website. www.siemens.com/gtac.
Also befor you replace (your expensive) Graphics card, you might want to check the recommended drivers. As I know a lot of my colleagues use this K4000 card without problems. So the card should not be the problem. Newer drivers might solve the issues.
Versions of NX are not listed, as the driver are certified for all supported versions of NX.
Look here: Hardware/Graphic Cards Certification
Kind regards,
Dennis
Dennis de Brouwer
Application Support Engineer
GTAC EMEA - Siemens Industry Software
