Group faces filtered by color
Hello to all,
I need a help to create a group of faces that I filtered by color using "Object Display" option.
Any help is very appreciated.
Best,
Danijel
Re: Group faces filtered by color
Layers is the answer.
Go to View tab, select 'Move to Layer', select the objects you wish to move, key in a layer value.
To show or hide the layers, go to 'layer settings' button in the view tab, and there you can find all the layers you created.
Let me know if that helps.
Paras Raina, Technical Head, MSC Systems Pvt. Ltd. (India)
NX 12.0.2
Solid Edge 2019
That's it.
Thank you!
@danijelVR
Going through your post again, you might want to look at 'group face' command in 'Synchronous Modeling' group under Home Tab. This also works if you just want to have the faces grouped together and behave as a single set, on which you can work later on.
NX 12.0.2
Solid Edge 2019
