Having difficulty to create section view from Broken view (Legacy).
Hello All,
I am working in automotive design. While working on some area I'm facing some issues with the broken view (Legacy). After taking the section from broken view, if that file will updates respectively the section will update but broken view will not update. That is the main issue I'm facing. Any one have solution regarding this, then please let me know.
I'm attaching the file for more clarification
Re: Having difficulty to create section view from Broken view (Legacy).
If the label on this post is accurate and you're running NX 9.0, why are you working with a 'legacy' Broken View?  Is this an old Drawing?  We never supported Section Views of the old style Broken Views.  Some have even argued that there is no Drafting standard that supports this (I can't verify this).  But if this is something that you really need to do, you may need to first replace the 'legacy' view with a new Broken View and go from there.
John R. Baker, P.E. (ret)
EX-Product 'Evangelist'
Irvine, CA
