Help file on blend and face blend
I seem to recall, from my aerospace days, that the NX help file had a section on blending the base of a blade/vane.  We have a situation now, which is similar, and I suggest the user look this section up in the help files, but now we can't find it.
Using NX9...is this still in the help?
 Dave
-Dave
NX 11 | Teamcenter 11 | Windows 8.1
Re: Help file on blend and face blend
Is this what you're looking for Dave?
I don't believe it's in the documentation any more.
You might also want to take a look at this:
Create a constrained curvature continuous face blend
Ben
That's it Ben, glad to know my memory isn't just making stuff up.  What version of the help file did you find that?
-Dave
-Dave
NX5 Smiley Happy
Thanks!
Any idea if the reason it's no longer included, is because the tool has been improved so as to not need it?
-Dave
I've submitted PR 7477282 for development to investigate.
Regards, Ben
