Help on Weld Assistance
how can I weld in the position indicated ?
Thank you...
Using NX11 and NX1847
RuleDesigner PDM
Re: Help on Weld Assistance
Hi Cubalibre,
Sorry i am not aware of any 1 step weld creation method for this weld...i will probably use a user defined weld for it.
I can  use the fillet weld but only when i have a proper intersection of the two faces (i used Replace face of the rectangular block face to butt on the cylindrical face.)
Best Regards
Kapil
Hi @kapilsharma,
sorry, but your response is far to the question.
Thank you...
RuleDesigner PDM
Hi Cubalibre,
Sorry i should have checked your parasolid file also.
Here is one more attempt from my side.Attaching a parasolid file also.  Please ignore the Weld PMI (i just attached it for display).
Best Regards
Kapil
Hi @kapilsharma,
I asked a different result. Don't worry.
Thank you...
RuleDesigner PDM
