Hide PMI Objects Flat-Pattern ?
Hello
Learned that Hide PMI Objects in Flat-Pattern hides Bend annotations.
- How to hide also all bend lines(violet,orange) with a single click ?
Re: Hide PMI Objects Flat-Pattern ?
The bend lines are controlled in the sheet metal preferences.
if you go to the tab flat pattern display you can set the lines on and of.
you can record these steps in a journal so that  you can create a button to switch te lines of or on.
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
