Hide pattern component
uncheck or hide pattern component in assembly doesn't change anything.
It's possible to hide or suppress a pattern component feature ?
Thank you...
Using NX11 and NX1847
RuleDesigner PDM
Re: Hide pattern component
This is a very poorly designed NX function. Check the following:
NX-Design-Forum/Pattern-Component-un-suppression-response
Michael Fernando
Die Designer
NX 11.0.2.7 + PDW
Hi @BenBroad,
there are some ER related to pattern components where ask to implement the suppress / hide function in the component pattern ?
Thank you...
RuleDesigner PDM
Hi @cubalibre00,
Yes, @mike_fdo submitted ER 7610946: "Pattern Component suppression state is not intuitive", but other than that there doesn't appear to be anything similar.
Regards, Ben
