Hole Dimension
Good day experts,
I just noticed, the Hole Dimension is now missing (removed) in NX 10?
Old version of NX has this command.
Thanks for the answers.
~Sen
Re: Hole Dimension
Sen,
dimension commands have been consolidated in NX10.
You should be able to create such a dimension with the "Radial" dimension type. You may have to switch the method to Diametral and/or adjust other options to make it look like what you expect.
But it is pretty straightforward to use.
Johannes
