Hole Table - Combination of 2 Holes
Dear all,
I am not succeeding in Customizing some Hole Callouts in the Hole Table
First I have first created a General Hole:
2Nd I have created a NPT Threaded Hole, Concentric to the First
Creating a Dawing gives me in a Sction View these Dimensions:
Adding a Hole Table gives me these results:
I do not succeed, in having the Depth of the Hole Diam. 6 corrected to another value. Threaded Hole is Fine.
Depth of the Hole Diam. 6via the Hole Table functions is giving me T13.66, wile I would like to see 35, as in the Hole definition.
Is this possible and if so how.
Best Regards,
Pascal
1 REPLY 1
Re: Hole Table - Combination of 2 Holes
Hi, have you checked your customer defaults?
Try changing these settings and see if you get the desired results.
