Hole table settings
Hi everyone,
I want to set settings of hole table globally. When I change decimal places in hole table, I need to do it again if I create new hole table. Should I make some changes in .pax files?
best regards
Lukipap
Re: Hole table settings
Hi lukipap
Use Customer Defaults for most global configurations.
Specifically -> File - Utilities - Customer Defaults - Drafting - General/Setup - Customize Standard - Table - Hole Table - Format - Decimal Places
johnpk
