01-24-2018 02:22 AM
01-24-2018 02:43 AM
Hi @KeyUser,
With appended text, use text formatting in the settings as shown in the image. But it is as good as using suffix except some space in between.
Ganesh
#IngenuityIsNX | NX - What's New
01-24-2018 02:59 AM
Unfortunately this solution will not work in our actual NX10 environment. Seems to be the extended functionality in NX11 or NX12.
01-24-2018 03:20 AM
Right. These are the part of enhancements in NX11. As a workaround, a note can be stacked with the inspection dimension by adjusting the dimension/tolerance text size and similar result can be achieved.
Ganesh
