Re: How can I set for display boundery highlights when I execute sew command and have some gaps?
Thanks to your attention for this issue.
I heard that my customer's system was not updated yet. His system is stll NX11.0.0.
So, I wll update his system to NX11.0.1. today. And I will let you know a result.
Thanks to everybody's advice!
Thanks to everybody's advice for this issue!
I was updated NX11.0.1. And my issue was solved!
Thank you very much!
Regards, Little Willie
Thanks to your advice for my issue.
I was solved my issue with your advice!
Thanks to your advice for my issue!
Your advice which hit the 'show result' button before hit the 'ok' was very important tip.
