How change the template.
For example if we are working sheet 1 template (Company A) , now i want to change the template ( Company B). But  it is two different template for different company . How it is ? And how to save template as seperate  template  file  and it will get into the drafting .
3 REPLIES 3
Re: How change the template.
Open up an existing template and choose "File > Save As".
Once you've created templates for each company, you can edit the drawing pax file, create a new entry for each customer's template and point to the corresponding template part file.  This way, when you select "File > New" and select the drawing tab the two templates will be listed.  Alternatively, you can simply create a blank drawing sheet and import the template part files.
Hope that helps
Regards, Ben
HI Ben,
Thanks a lot. If you don't mind can u show this in videos.
Sivakumar Murugavel
Hi @S7,
Please review the following movies and let us know if you still need assistance.
Thanks, Ben
