How do I create a hollow tubing system out of a complex 3D structure of blood vessels?
The structure is currently a solid body with an outer surface consisting of multiple (around 22'700) small surface areas and its interior is completely filled making it a solid body. I eventually plan on 3D printing the model. I'd like to make it hollow with a constant wall thickness.
Thank you!
Re: How do I create a hollow tubing system out of a complex 3D structure of blood vessels?
Hi @YannF , Please attach an image.
Samadhan
GTAC | NX Help: NX1102 | NX1202 | NX1847
Please mark post as an "Accepted Solution", if it answers your question/is more helpful!
