How do I permanently turn off the "Warn on delete" of assembly components?
There is a user preference to turn this off, but it is only for that session.  Is there a way to permanently turn off the message that appears when you delete a component from an assembly?
Scot
Re: How do I permanently turn off the "Warn on delete" of assembly components?
Hi @kzndgg,
Warn on Delete is a session setting and can't be permanently disabled.  Please consider contacting your local GTAC office and ask that you're added to ER 6961214, which requests the functionality you're looking for.
Regards, Ben
