How reset NX
I have accidentally Removed to gallery a couple of headings from (More)Tab..Then i removed (More) itself. So its all messed up now..How can i have the layout as it was initially.. <I am a new user>
5 REPLIES 5
Re: How reset NX
Hi @jake1,
From Role navigator, select role under content folder > RMB > Apply. You can customize ribbon bar menu,commands and save it as new role.
Refer Create a custom user role help documentation and related links for more information.
Re: How reset NX
Thanks a lot Sir!
Re: How reset NX
@jake1,
It might be a good idea to save your role to a location where you will have read/write access before you make any interface changes - then if you make a mistake, you can at least load the role you last saved and not have to start all over.
Tim
NX 11.0.2.7 MP11 Rev. A
GM TcE v11.2.3.1
GM GPDL v11-A.3.7
Re: How reset NX
How do i save a role? I am a new user..
Re: How reset NX
@jake1,
Menu -> Preferences -> User Interface -> Roles (on left) -> New Role (on right) -> Save As dialog. This is where you can also load a role using Load Role (under New Role).
Tim
GM TcE v11.2.3.1
GM GPDL v11-A.3.7
