How to Automatically Orient the View to Sketch after the Plane is selected for sketching?
After I select the plane for sketching, I have to automatically select the orient the view to sketch command (Shift + F8) to make the view normal to the plane. Is there any option in NX 7.5 so that I can do it automatically?
Re: How to Automatically Orient the View to Sketch after the Plane is selected for sketching?
You have to change the Customer Default 'Change View Orientation' under 'Sketch -> General -> Tab: Session Settings
Regards André
In NX 7.5 the option "Change View Orientation" in the sketch preferences dialog only works for the Sketch Task Environment. In NX 8.5 the option was made to work for Direct Sketch.
Regards, **bleep**
There is no option to do that in NX 7.5. The only way is to right click and select Orient View to Sketch or by Pressing (Shift+F8) command.
