How to Copy the Assembly with Wavelink in NX-9?
  • Im using NX-9
  • I want to Copy the Assembly with Wavelink(Without Broken) For the Below Assembly Structure
>Assy-1 (Contains Wavelink)
  • Part-A1 (Contains Wavelinks) [(x,y,z)=(50,20,100)]
  • Part-B1 (Contains Wave links of Part-A1)
  • Part-C1 (Contains Wave links of Part-A1,B1)
[Now i Want to copy this assembly and rename to Assy-2]
>Assy-2 (Contains Wavelink)
  • Part-A2 (Contains Wavelinks) [(x,y,z)=(70,40,100)]
  • Part-B2 (Contains Wave links of Part-A2)
  • Part-C2 (Contains Wave links of Part-A2,B2)
For this case,
      if i'm using Make unique option and rename, i'm getting Assembly & parts with broken wavelinks.Again in again i have to use synchronize links option to generate wavelinks. It makes me tedious, Because every parts have 50-70 linked datums,curves,axis.
     if i'm using Save as option, Afterwards It can't able to move the part co-ordinates(x,y,z).
Query:
     Is there any better option available for Copy the assembly without wavelink broken.?
Re: How to Copy the Assembly with Wavelink in NX-9?
Use 'Clone Assembly' and option Full.
Menu > Assemblies > Cloning > Create Clone Assembly
https://www.youtube.com/watch?v=PAg3w5yJ81w
Ganesh
Thank you for your Solution.
I will try this option and let you know..
