Re: How to Create Section view from a break view in NX 8.5
@cubalibre00
Thank you for the quick reply.
I did not understand completely...if possible then can you please elaborate?
will be a great help!!!
Chetan
Hi Scott,
Gladly Smiley Happy
Image and sample part file attached.  (drawing in same file as model for ease of file transfer only)
Trying to create a section view from a broken view.. If the section is perpendicular to the break, the section lines still hide and display the same on screen messages. I think this is the same behavoir for this use case back to NX8.0.
Ryan
seems i can't attach test.prt file directly... maybe the zip will work
Yes in NX 11 it works across the view break but not perpendicular to it. I would open an IR for this use case to get it taken care of.
Community.pngView Break and Section Views
Sorry I could not give you the answer you where looking for,
Scott
Hi Scott,
No problem, you did answer it. The answer is... "It still isn't possible."
I'll open an IR.
Ryan
