How to Dimension in Realize Shapes
Hello Everyone,
I was wondering if anyone has found a method to get realize shapes to hit exact dimension dimension targets? Such as set to point apart by 1" similar to the dimensioning in the sketch tool. Thanks in advance.
Re: How to Dimension in Realize Shapes
You can use something similiar to this to merge an NX Realize Shape body into a controlled size.
See the part on Merge
Check out the Merge movie.
Scott
